Thread: osborne bottle/wine cooler
23-11-2007, 11:58 PM #1
Hello guys, today I had a look at a couple of osborne upright single door wine/bottle coolers with the condensers at low level on the front (exposed). The condenser looked fairly clean from the front but when I pulled the guts out from round the back to change the fan motor, the inner side of the condenser was chock a block with dust so the fan was blowing out towards the front through the coil. I thought these were supposed to pull through the coil from the front rather than blow through from the back, or am I being silly? I put the new motor in and it did exactly the same, looked at the other fridge and that did the same as well.
Am I being silly or is it the way they designed the upright ones?
Andy
24-11-2007, 12:32 AM #2
Re: osborne bottle/wine cooler
Not always unusual, not smart but there you go - someone thought it was a good idea.
24-11-2007, 02:16 PM #3
hey mate yeah it is a bit silly but makes sense really, it is designed to pull air over the compressor so you are not getting rid of the heat of compression over the compressor other wise it would overheat..
if you look at it like that it makes sense..
Designs are usually for a reason..
26-11-2007, 05:18 PM #4
Common for an Osborne.
mojonnier carbo cooler common system
By guapo in forum IndustrialReplies: 9Last Post: 16-06-2011, 05:20 PM -
NH3 thermosiphon oil cooler
By cygbob in forum NH3Replies: 38Last Post: 22-06-2008, 05:12 PM -
TXV hunting in a walkin cooler
By dkemper in forum Trouble ShootingReplies: 9Last Post: 15-11-2007, 03:14 PM -
Walkin cooler
By masooda in forum Trouble ShootingReplies: 4Last Post: 09-02-2007, 04:57 PM -
Thermo-syphon Oil Cooler
By B.B. in forum IndustrialReplies: 5Last Post: 31-10-2005, 01:25 PM
