Thread: Bosch KGV3120GB Fridge/Freezer
18-11-2007, 05:55 PM #1
Help Wanted please
I am a retired Electrician/CCTV engineer, recently after my wife defrosted the
freezer, and when switched back on again, the compressor did'nt start up. I put the supply straight to compressor and it started to run ok. I am sure the termistor is faulty. I have heard that if I cut the wires to the termistor and twist them together the machine will work ok and will be controled by the temperture control on the panel. But with no thermistor, what controls the freezer temperature?
If I get a replacement termistor, is it difficult to fit? Any help would be appreciated.
Towbar
18-11-2007, 06:42 PM #2
Re: Bosch KGV3120GB Fridge/Freezer
join the 2 middle wires together (Dark Blue with Dark Brown) and it will work and should carry on as norm,as for replacement termistor,they very easy to fit
19-11-2007, 06:19 PM #3
tono33
Thanks for that info. I will try that, and fit new termistor when I have sourced one.
Towbar
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Bosch Fridge Freezer Error Code ??
By madfriday in forum DomesticReplies: 3Last Post: 29-04-2010, 09:01 PM -
Westinghouse Silhouette 391 fridge/freezer
By Bones in forum DomesticReplies: 2Last Post: 04-05-2007, 03:05 PM -
lg fridge/freezer fault light on function display board
By bazza in forum Trouble ShootingReplies: 0Last Post: 25-02-2007, 03:25 PM -
RFI Interference from Fridge/Freezer
By pathfinder in forum Trouble ShootingReplies: 6Last Post: 19-03-2005, 11:50 AM
