Results 1 to 2 of 2
    Jun 2006
    Victoria
    44
    27
    Question Talcum Powder, Copper Pitting?
    Howdy Peoples!
    Was insualting 1 5/8" suction lines today for a packing cool room. I use some baby powder to help the insulation slide onto the pipes..
    My buddy tells me that he does not like to use talc powder as he has seen bad pitting on copper tubes due to the use of talc?
    Has anyone heard or experienced this? Are there any other products or methods that can be used to make the job easier without talc?
    Kind Regards
    Dale
    Aug 2001
    1,046
    Re: Talcum Powder, Copper Pitting?
    Traditionally, it should be engineer's French Chalk (which is, after all, Talcum powder without the perfume and the drying agents).
    I used it for years, because it was easier to get than French Chalk – you can buy it anywhere.
    So long as the tubes are securely capped so that it does not get in the pipe, it's fine - it is a mild abrasive, so you don't want it in the system.
    It makes threading obstinate insulation much easier, but make sure that it is not on the mating insulation surfaces if you are going to apply a vapour sealer to the joins as it will inhibit the adhesion.
    If it corrodes copper pipe, what’s it going to do the baby’s bum? I think you are being wound up.....
    Enjoy the experience – it’s fine.
  1. joining copper to copper, joining copper to brass
    By mac_J in forum Technical Discussions
    Last Post: 15-01-2008, 02:29 AM
  2. Copper tube degreasing specification
    By Thermatech in forum Technical Discussions
    Last Post: 23-05-2007, 03:10 PM
  3. yellow powder
    By John Wood in forum Refrigerants
    Last Post: 11-07-2006, 10:31 PM
  4. oxidation scale in copper tube and fittings
    By DeB in forum Fundamentals
    Last Post: 23-06-2006, 09:45 PM
  5. reduce thickness of bended copper tubes
    By rlim in forum Air Conditioning
    Last Post: 08-07-2003, 10:58 PM
