    Andrew F.'s Avatar
    Andrew F. Guest
    Refrigerant oils
    I am a first year apprentice refrigeration mechanic from sydney australia. i'm looking for answers to an assignment thats due in real soon. i'm looking for the definitions for:
    material compatibility
    refrigerant compatibility
    chemical stability
    traction co-efficient
    I'm also looking for selection criteria for oils used within the HVAC industry and safety issues when using refrigeration oils in terms of:
    safe handling
    if anyone can help me really appreciate it, if you can't thanks anyway.
    Oct 2006
    1,843
    21
    Re: Refrigerant oils
    Quote Originally Posted by Andrew F. View Post
    chemical stability
    safe handling
    Andrew if we were to give you the answers would that help you in the long run.
    Your tutor has assigned you this work to challenge you. Where is the challenge in just asking for the answers.
    If it needs to be in real soon what have you done between the time the assignment was set and now.
    Try and find the answers from the web and from books.
    All the best taz.
    PS how do you know your tutor does not contribute to this site.
    taz.
    Aug 2007
    Sydney
    52
    1,083
    23
    Good morning Andrew
    Your local Actrol supplier (Auban is best) would be able to help with the first part of your question. As for the second part you should ask for the material data hazard sheet ( or what ever it's called ) required for all chemical products in Ausi. You should have completed your green card which teaches the same. A couple of things come to mind with oil safety 1, pressure. 2, Acid in conaminated oil. 3, micro organisims which grow in some oils - wear ppe gloves glassses and dispose of correctly. Hopefully in 20 years there will be no oil compressors left.
    Good to see you found this site. Look forward to your next post
    Tesla
    Jul 2009
    Australia
    33
    The guy is asking for some help. He came to this site to ask questions and hoping to find answers.
    I have the exact same questions.
    katie2153's Avatar
    katie2153 Guest
    hey, I am also a first year app, i seem to have the same assignment as you by any chance did you find the answers?
    katie
  1. R600 Refrigerant.
    By tonydeith in forum Refrigerants
    Last Post: 21-04-2011, 08:52 AM
  2. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  3. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  4. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  5. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
