Thread: Screw compressor Oil pump
Threaded View
10-11-2007, 12:35 PM #1
I work for a company that built refrigeration packages with oil flooded screw compressor; we had problems with our oil pump, screw type, supplier so we are looking for another one but it seems not easy to find. Our typical operative conditions of the pump, are the following:
P suction: 15-23 barg
Delta P: 3-5 bar
T oil: 40 - 90 °C
Flow rate: 500 to 2000 liters/min
In some applications, depending from the oil type, refrigerant can be mixed to the oil.
Please suggest me possible vendors for this type of pump, alternative solutions will be appreciate also.
Thanks.
Michele
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Help with condensor pump
By Bakerbj in forum Air ConditioningReplies: 23Last Post: 14-06-2009, 12:39 AM -
advantage of twin screw compressor over single screw compressor
By azzah in forum New to REReplies: 7Last Post: 23-09-2008, 09:24 AM -
frostles heat pump
System Pump Down
By Brian_UK in forum Technical SpeculationsReplies: 16Last Post: 25-10-2001, 10:39 PM
