Thread: carlyle compressor
08-11-2007, 06:55 PM #1
carlyle compressor
hi everyone
ive been asked to fit a carlyle comprssor on a old unit,the problem being that the new compressor is over 10 years old, it is new but been in the customers plant room for that length of time.will this be ok to fit..
sid
08-11-2007, 07:49 PM #2
Re: carlyle compressor
Don't see why not, so long as it is the correct model and is sealed up propperly. Its got to be in better condition than one that has been running for ten years.
Jon
08-11-2007, 08:43 PM #3
Open the oil pressure , and pump oil by it, just a few qty
09-11-2007, 12:10 AM #4
I would suggest taking the end plate off so that the free rotation can be checked.
While it is open spray some oil about and see if you can persuade the oil pump to do some work as well.Brian - Newton Abbot, Devon, UK
Testing Inverters
By fridge doctor in forum Air ConditioningReplies: 38Last Post: 15-06-2011, 06:52 AM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM
