08-11-2007, 02:38 PM #1
Sea side wind resistant condensing unit fan
Hello,
Could you help me something about air conditioner installation at high rise building.
How to check air circulation of condensing unit that face to sea side wind (counter flow)?
09-11-2007, 12:21 AM #2
Re: Sea side wind resistant condensing unit fan
Hi Samurai and welcome to the forum.
You would need to use an anemometer to measure the airflow through the condenser coil both when the wind is high and when the wind is low; this would tell you what effect the wind is having.
Is it possible to turn the unit through 90° so that the wind blows across the coil and not through it?Brian - Newton Abbot, Devon, UK
22-11-2007, 01:47 AM #3
Thank you so much for your advice... ^ ^
condensing unit installation
By jeguzar in forum Supermarket RefrigerationReplies: 1Last Post: 28-09-2007, 05:02 PM -
TXV sizing with a larger condensing unit
By kengineering in forum Technical DiscussionsReplies: 13Last Post: 27-08-2007, 10:44 PM -
M I T S U S H I T A ac unit with no condensing unit
By Chinua in forum Air ConditioningReplies: 2Last Post: 28-07-2006, 06:54 PM -
Matching Evaporator with Condensing Unit
By Abe in forum Technical DiscussionsReplies: 12Last Post: 25-07-2001, 08:57 AM
