Results 1 to 9 of 9
    scherif's Avatar
    scherif Guest
    Thumbs up design of expansion tank
    hi,nice to send my 1 st message,my q is how to design the expansion tank in hydronic system
    Jun 2001
    N.Ireland
    1,630
    Hi, Scherif
    you could always dispense with the header tank and fit an autoclave (bladder), these are sized according to the system internal volume and operating temperature range.
    Failing that I can add a link to the Grasso site where they have a very good description of a hydronics system.
    Regards. Andy.
    Nov 2006
    Poland
    91
    Re: design of expansion tank
    Quote Originally Posted by Andy View Post
    Hi, Scherif
    Regards. Andy.
    Hi Andy.
    Could you give us the link you mentioned above. I'm very interested in chilled water systems.
    Thanks in advance!
    Regards form Poland.
    Jacek
    Feb 2008
    Suadi arabia
    7
    Dear Andy
    Your help is very much needed in this area. We are designing a system for a fresh-cut factory to work with glycol. I need to confirm with the supplier the tank size. So I am looking forwared for your input.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by aansari View Post
    Dear Andy
    You could do quick calculation here:
    http://www.elbi.it/configurat/body.pe
    or you could download software here:
    http://www.reflex.de/reflex/pdf/reflex4_de.exe
    China
    55
    52
    many engineers don't know the details about a expansion tank. this topic needs more discussion
    regards from China
    yangchenchen
    iminsincere's Avatar
    iminsincere Guest
    i need some expansion calculation.
    1) System total hot water volume = 1,300 cu. meters (Including pipeliens & boilers)
    2) Boiler Design Pressure = 200 psig
    3) System Pressure = 10 bars (145 psig)
    4) Water Inlet to Boiler = 140 deg. C
    5) Water Outlet from Boiler = 155 deg. C
    how much will be tha expansion
    Apr 2008
    phillippines
    125
    Mate,
    The thread is more than a year.
    MrEngr's Avatar
    MrEngr Guest
    Goto engineermanual.com and search for expansion tank, there is a page there that explains it well.
  1. expansion water tank sizing program
    Last Post: 01-09-2005, 04:24 AM
  2. Expansion
    By alesindo in forum Fundamentals
    Last Post: 30-07-2005, 09:16 AM
  3. water expansion tank
    By Lc_shi in forum Air Conditioning
    Last Post: 30-01-2005, 11:49 PM
  4. pressure drop between expansion valve and distributor
    By aygul in forum Technical Speculations
    Last Post: 22-01-2004, 09:47 AM
  5. R507 in an R134a compressor: system design
    Last Post: 01-05-2003, 09:25 AM
