    Oct 2006
    CORDOBA -ARGENTINA
    69
    69
    12
    REF COM compressor
    Hi I need data about a REF COM semi hermetic compressor
    REF COM model SRC L085-MO
    380 volt. 71 amp.
    ref R 22.
    It is used at a water chiller I have not the CHILLER Brand .
    There are four of each compressor at the chiller.
    Thanks in advance
    May 2006
    India
    77
    1,016
    14
    Re: REF COM compressor
    Please visit www.refcomp.it . You will get all the datas and the selection software of RefComp compressor.
    Oct 2006
    CORDOBA -ARGENTINA
    69
    69
    12
    Thanks , I can not register , the web page does not work .
    Could you send me the software.
    devitg@gmail.com
    May 2006
    India
    77
    1,016
    14
    The Software is available on the web site and to enter the download area you have to register and then log in. It is not possible to mail the set up as the same is valid for the computer you have registered and logged in.
    Sorry I can not be of help to you. I shall try some other means and see if it can be done.
    May 2006
    India
    77
    1,016
    14
    Please try and see if this link of the setup works or not.
    http://download.yousendit.com/33DEBEFE0B5C6900
    Kindly let me know if the software could be downloaded
    May 2006
    India
    77
    1,016
    14
    Could you get the details of the RefComp compressor. If not please do let me know, as I have some details with me.
    Jun 2010
    China
    12
    Here's a bit of history and contacts if you need them.
    RefComp and Thermokey form together the RTH group which is an independent group which has one owner who is the original founder Mr. Candio.
    RefComp makes the very same screw and piston compressors at their factories both near Vicenza in Italy and in Shanghai in China while Thermokey makes many types of heat exchangers for Air Con, Refrigeration , Process Control, Close Control , Power and Energy and Solar Energy markets and manufactures in Italy , China and Brazil.
    About 30 years ago Mr. Candio used to own Artec (heat exchangers) which he after sold to Alfa Laval. After RefComp was then founded and was a pioneering company with screw compressor technology specifically designed for HVAC and Refrigeration applications. During this past century Bitzer used to sell the large RefComp screw compressors through their sales network because back then they did not manufacture yet this kind of new screw compressor.
    After Thermokey was then founded. Nowdays Thermokey is pioneering in large aluminium microhannel heat exchangers specifically designed for HVAC and Refrigeration applications
    you can contact them at :
    sales@refcomp.it
    sales@thermokey.it
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. Mitsubishi compressor lock
    By marc5180 in forum Air Conditioning
    Last Post: 08-10-2007, 05:48 PM
  4. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
  5. Compressor failure...... cause
    By herefishy in forum Technical Speculations
    Last Post: 06-12-2002, 12:15 AM
