Thread: R134a
    Mar 2007
    Malaysia
    5
    R134a
    does anyone knows this equation (see attachment) which been derived from Martin-Hou's equation of state for R134a.
    it seems that i cant get the value right even after using the values from DuPont's..can anyone help me out here?
    Attached Files Attached Files
    Aug 2005
    5,302
    Re: R134a
    If the derivation and coefficients are correct, then it's a math error someplace. It's been a long time since I have worked with this, but are you sure about the actual equations and coefficients from Dupont?
    Nov 2006
    63
    392
    Re: R134a
    Sorry
    were does "A" come in to the equation, I was with it until then but I lost it after that.
    Ian
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. r134a as a substitute for r22?
    By m-nelson in forum Supermarket Refrigeration
    Last Post: 24-08-2007, 11:16 PM
  3. Pressure Transmitter R134a Setpoints
    By cooltrain in forum Technical Speculations
    Last Post: 28-02-2005, 09:05 AM
  4. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
  5. R507 in an R134a compressor: system design
    Last Post: 01-05-2003, 09:25 AM
