Results 1 to 8 of 8
Thread: old chiller update
26-10-2007, 03:14 AM #1
old chiller update
hi,i have an chiller its about 20 year old,and was thinkin about re wiring it with more updated controls,anyone know of a controller out there that would be suitable..ie programable inputs and out puts..
rgrds phil
26-10-2007, 04:48 AM #2
Re: old chiller update
Hi Phil
Carel make a range of controllers that may be suitable. www.careluk.co.uk or www.carel.com
Paul
26-10-2007, 09:30 AM #3
Hi Phill
I'v seen Innotech controllers used for chiller control before and carrel controllers. I am employed as a controls tech and know there are hundreds of controllers to do the job, all you need to specify is the I/O's and control functions to perform like Proportional Intergral loops or CHW Reset. Best bet is something that has a display and you can plug a laptop into for programming and commissioning.
13-12-2007, 08:25 PM #4
I've rewired a few units with carel PCO2 controllers plus EXV driver boards running sporlan SE250 valves ran good as gold. I can send you a copy of the drawings if you like
13-04-2008, 01:14 AM #5
Phil
Dixell have a chiller controller, the tricoods used to come with it, you can use pressure switches for the fans, have redone some old units like this. PM me if you need any info, i can travel anywhere for a fee!!
Al
13-04-2008, 01:52 AM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
13-04-2008, 10:31 PM #7
13-04-2008, 10:55 PM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Water Chiller
By lana in forum Technical SpeculationsReplies: 20Last Post: 23-06-2007, 01:19 AM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
