Results 1 to 2 of 2
Thread: About Delta T
    Mar 2007
    UAE
    43
    78
    About Delta T
    Kindly suggest for my queries
    System : Cold Room
    Room Temp :0ºC
    Total Heat Load : 42 KW
    No of Evaporators : 2
    Evaporator capacity: 21 KW each
    Secondary Coolant :35% Prop.Glycol
    Glycol Inlet :-8ºC
    Glycol Outlet :-4ºC
    Flow rate :9.4 m3 /Hr. for a single unit.
    Query:
    • Here the T = 4ºC is common. Suppose I make the Inlet /outlet temp.like -10/-6ºC (OR) -1 / -5ºC what will be the result to the room temperature? How can I justify while selecting the equipment?
    • Considering 7 cold rooms to the same capacity & same parameters the number of evaporators is 14. I have to store the glycol in a tank and rechilling it thro PHE. How can I calculate the flow rate for PHE?
    Waiting for your suggestions.
    Oct 2003
    5,630
    34
    Re: About Delta T
    You can say that your capacity will drop +/- linear with the DT.
    For me, your DT is 8K (room at 0°C and glycol entering at -8°C)
    Now, you will enter at -5°C.
    So a drop of +/- 37%
    Q= k.A.DT (k and A remains the same)
    Flow rate, is it not just 9.4/unit x 14 units?
    Evaporating at 5 to 7 K lower then the desired outlet temperature of -8°C (so -13°C to -15°C)
    You will need software to calculate this because each manufacturer can tell you what capacity you will have with a specific glycol mixture. Don't forget also that the viscosity will increase with lowering the temperature.
    You will need bigger pumps.
    Pressure drop will also increase due to the large mass flow of 14 units
  1. Part Wind/ Star Delta
    By reggie in forum Technical Speculations
    Last Post: 27-08-2008, 05:47 AM
  2. Understanding star delta
    By marc5180 in forum Fundamentals
    Last Post: 26-09-2007, 01:21 AM
  3. Replies: 12
    Last Post: 18-03-2007, 05:25 PM
  4. 3phase compressor.
    By Pandrone in forum Air Conditioning
    Last Post: 11-01-2005, 09:34 PM
  5. Large tonnage De-coupling
    By MANIS in forum Technical Discussions
    Last Post: 14-08-2004, 06:29 PM
