    Apr 2007
    canada
    58
    29
    Horsepower needed for 20 ton icemaker
    What is the horsepower requirement needed for a 20 ton ice maker . I'm looking at replacing a 10 ton ***** (R-402A) ice machine with a 20 ton ammonia unit .
    Is there a formula for figuring this out ??
    Mar 2006
    dallas, texas
    75
    108
    Re: Horsepower needed for 20 ton icemaker
    there are good rule of thumbs but it depends on the ice maker brand, and the entering water temp
    turbo, vogt tube ice is approx 1.5 ton per ton of ice
    at -10 suction with 60 degree water .
    northstar style flake is is approx 60 df water 1.3 ton per ton of ice at -25 to -30 df suction.
    these numbers work very well for good ice production.
    bruce boldy
    Jun 2001
    N.Ireland
    1,630
    Quote Originally Posted by bruceboldy View Post
    bruce boldy
    Ta Bruce,
    I have worked on a few North Stars, Model 90E's I remember working out the duty of one with a 6WB Mycom on it as we were changing the condenser, this I gave to the technical director and he used a check figure to tell me I was close enough, I now have the check figure.
    Kind Regards Andy
  1. Autocascade refrigeration system: design verification needed
    Last Post: 07-02-2010, 07:48 AM
  2. Smart/As needed evap defrost?
    By dkemper in forum Fundamentals
    Last Post: 27-10-2008, 07:25 PM
  3. Extra Horsepower From Cooling Intake Temps
    By BigJon3475 in forum Technical Speculations
    Last Post: 12-07-2007, 01:37 AM
  4. Horsepower and Kilowatts
    By baker in forum Air Conditioning
    Last Post: 23-03-2004, 09:17 AM
  5. Horsepower = Tonnage
    By acman in forum Fundamentals
    Last Post: 31-05-2003, 03:10 PM
