Thread: York Chillers
23-10-2007, 02:20 PM #1
York Chillers
Hi guys, have an odd one here, have two york chillers on site, mod:ycva-55L-50B. Both chillers will shut down completly, have power to everything!! all pressures fine, but if i replace the inlet water sensor they imediatly start up again, being so old there is no fault code system, and it is imposs to get hold of york tech division, has anyone come across this prob or have any solutions??
Many Thanks...
23-10-2007, 03:47 PM #2
Re: York Chillers
make sure that all the sensors are in place and working correctly
23-10-2007, 08:38 PM #3
Re: York Chillers
What was the water temperature at shutdown?
23-10-2007, 09:30 PM #4
Re: York Chillers
try this contact number its for york/johnsson controls
they can e-mail you a manuel 01628246418
25-10-2007, 04:43 PM #5
Re: York Chillers
Hi guy's, had a day off hence late reply, to themba sensors are new and seated correctly, paul thanks for that number will contact them, and brian water temp when unit cutting out is approx 9.5 deg cels..
Just to clarify this has happened four times, and like i say popping a new sensor in seems to do the trick, but obviously cannot keep doing this!!
17-11-2010, 07:36 PM #6
Re: York Chillers
Please, does anyone have the manual for York mod:ycva-55L-50B?
Thanks in advance
Carlos
YORK ducted split
By ALONEI in forum Trouble ShootingReplies: 7Last Post: 10-07-2010, 02:18 AM -
centrifugal chillers york
By Magic in forum Technical DiscussionsReplies: 6Last Post: 12-11-2009, 06:08 PM -
Air cooled chillers vibration isolation
By vijay_study in forum Air ConditioningReplies: 3Last Post: 06-10-2009, 08:53 PM -
York Millenium Vc Chillers
By cj1011 in forum CommercialReplies: 0Last Post: 16-10-2007, 10:14 PM -
york gs/ gsi chillers
By GHAZ in forum Technical DiscussionsReplies: 1Last Post: 16-09-2007, 10:42 PM
