Results 1 to 9 of 9
Thread: basic refrigerator properties
17-01-2003, 09:30 PM #1
Hello, I am trying to get a basic feel for the power, COP, and cost of traditional refrigerators so that I can compare them to peltier devices. I know that refrigerators are typically much cheaper on large scales, but I am not sure exactly what happens on small scales. I have looked at some refrigerator spec sheets, but so far, they have not said anything about power or heat transfer. They only mention size and temperature. Can someone direct me to a good resource?
Thank you,
Andy
21-01-2003, 02:24 PM #2
Dear Andy,
I can't help you with refrigerator specifics because as you correctly put it, they don't reveal much. But the compressor power and refrigerating capacity in W is most of the time given.
Done a comparison some time ago between using thermoelectrics and mechanical refrigeration. Economically, due to high cost of TE modules , the traditional mech. ref. system is less than 1/3 the cost of using TE air-to-air modules. Do you have a cheap source of TE modules ?
Bernard
21-01-2003, 06:24 PM #3
COP is watts of electricity divided by btus of heat removed. Spec sheets have BTUs and Watts on them. COP is easy to find.
That is just the compressor though. The heat loss on the box detirmines how much compresser capacity you need. There are refrigerators out there the run on 1/3 the electricity of a standard refrigerator. Add a couple of inches of insulation to your frig and you will be able to see this too. Low power semi conductors can do a good job of cooling with lots of insulation.
21-01-2003, 06:40 PM #4
Thanks for your replies.
To bersaga: Nope, no cheap source of Peltiers. Sorry. We're just investigating.
To superheat: I have seen the BTUs mentioned with air conditioners, but not refrigerators. So far, I've just been going to GE's, Kenmore's etc. website and snooping around and their spec sheets haven't mentioned BTUs. If you get a chance, can you tell me where you've seen it?
21-01-2003, 06:51 PM #5
Actually, COP is a dimensionless number. Cooling capacity in Btu/hr divided by electrical input in watts gives you an EER value. One can convert EER to COP with the following:
COP = EER / 3.412
BTW, a SEER rating applies only to residential air conditioning equipment, and it involves several tests. So one cannot derive a SEER value simply knowing EER at some given operating condition.Prof Sporlan
21-01-2003, 06:57 PM #6
BTUs will be given on the compressor spec sheet. ASk the manufacturer.
You are right Prof. I got those 2 backwards again. I have always wondered if the EER numbers on the compressor sheet really mean anything. Change the coils to a bigger or smaller size and the system has a new eff. with the same compressor. What is the standard they go by?
22-01-2003, 12:45 AM #7I have always wondered if the EER numbers on the compressor sheet really mean anything. Change the coils to a bigger or smaller size and the system has a new eff.Prof Sporlan
31-03-2003, 07:20 AM #8
Without having to get a 37 year college degree in heat transfer/fluid flow, how would you determine line size versus evaporator?
What if you split a system?I visit http://www.fuel-saver.org
03-04-2003, 03:30 AM #9
I would size the line per the compressor's capacity at design conditions. I would not pay much attention to the evaporator.
What is the Basic Function of a Rapid Purger ?
By eng_ab in forum IndustrialReplies: 3Last Post: 11-06-2006, 07:53 PM -
Basic SMALL refigeration system
By M@@Home in forum FundamentalsReplies: 13Last Post: 01-06-2006, 08:19 PM -
Help with a basic design for a Safari Vehicle
By Jeromy Dacey in forum DomesticReplies: 0Last Post: 14-12-2005, 11:38 AM -
The Basic Law of MRC ?
By MANIS in forum Air ConditioningReplies: 0Last Post: 23-09-2003, 09:21 PM -
basic operating principles of compressors
By alanmongey in forum FundamentalsReplies: 2Last Post: 13-09-2001, 01:53 PM
