Permafrost,
Where are the Philippines are you building? What type of lighting are you planning to use?
Permafrost,
I'm building the facility in Taguig City, Metro Manila. I'm hoping to use LED but haven't really gotten around to checking out potential suppliers. Why do you ask?
I have done several LED projects in Cold Stores in the Philippines, and have some good contacts for LED lighting services in Makati City. Please let me know if you are interested in any more info.
To all who have responded to my questions, thank you for your inputs. They are highly appreciated. I'm thinking of just going with either Isocab or DC-system for the panels at 13.5m length (vertical installation) and 175mm thick for outside and 150mm for inside. Probably Frick compressors. I'm also looking at revising the layout from double deep to VNA. I'm looking at Linde K-series VNA trucks. Going with either SAP or Oracle for ERP and WMS. Hybrid RFID and barcode labelling.
aaronnk,
yes i'm interested in LED lighting. where are you based? what's the name of your company?
Hi Permafrost,
I hope im not late to give you a proposal for your project. I was hooked where you will build your facility because i was born there in Taguig City . Im working now in Dubai for an Italian Company in which i can give you a proposal for the coldroom panels and LED lights. Just let me know your email address and i will send to you my proposal.
Hi all
If you need to make some calculations on needs for a Cold Room, you can use the following online application, is very useful:
Refrigeration Calculator v3.2
http://www.intarcon.com/en/index.php
INTARCON is a company in Europe dedicated to the manufacturing and design of refrigeration equipment, and offers this calculator for helping engineers worldwide.
permafrost888, i will presume that you are already a member of the cold srorage oprerators here. otherwise, it would be a wise move, so that you will get to know the other operators(and possible competitors), and usually, you can get some advise / feedback from them. we operate an ice block plant, but only use recips(ammonia refrigerant). My personal experience with compressor parts ? grasso usually have spares available(most of the time), same for mycom. but i always had problems with local sabroe parts . my experinece is that inventory of parts is very limited, and at times they wil indent order for you but it will take forever. also had the misfortune of having ordered parts thru them, waited for a very, very long time,. only to later know that the parts i ordered thru them were wrong. the local parts supplier didnot even bother to check the parts before sending it to us. but maybe it is only with me. just my experience.
Hi permafrost888,
Hi permafrost888,
Can i have you email address so we can contact you for further consulting .
