Re: Thermoking Magnum Plus 203 service manual
Welcome
I have one question. I have a TK TS200 and Thermoguard read bat = 10.6V on the generator is 13.6V. After 10-15min, the unit turns off and the display ALR 25
Where could be the cause?
Thanks in advance
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Hi reefermachanic , can you please help me with a service manual and diagrams for a Thermoking V250 ? My email is AR74Hog@yahoo.com
Thanks so much !!!
I need help with my mitsubishi tu73d. I need an english service manual and english electrical diagram.
Please send me a private messsge if you csn help. I cant understand the controls of the systemcoz its in japanese
Hi reefermechanic,
I'm in the haulage business,my co. recently decided to try our hands on refrigerated transport so we purchased a Thermoking V500 max tc 20 mounted on a mercedes benz atego truck from England.
TK unit was supposedly working when purchased, but when we took delivery of the truck we discovered that the printed circuit board was missing from the unit.
We have ordered for a new PCB and we have mounted it with all required relays and fuses.
The problem now is that the in-cab control box comes on,displays the return temprature and the set.point temperature, but the unit does not come on,the fans do not work and there is no indication that the unit is working at all, even though the cooling indicator light is on.
We are still trying to run it in vehicle mode.
It is a 24v unit.
We have also tried in vain to locate fuse F21 which supposedly supplies power to the unit from the vehicle battery.
Please do you have any ideas how we can get the unit running? or any ideas what may be the problem.
Thanks a lot.
Hi Guys,
Pls ask the questions to me about refrigerated container units.
All the best,
See you
Reefermechanic
Hi Reefer Mechanic,
Would you please help me to download a operation manual for CD TTT M5, please send to:
passionplayer@live.com
best regards
Thanks a lot!
Hi GokspeksYou need help still?See youreefermechanic
GoksPeks
Hi reefermechanic,unfortunately I have no internet access all the time,because I am currently onboard.I have operation manuals of all reefers,but I need service manuals and additional service tutorials about Carrier troubleshooting.Anyway,if you are willing to help and send some useful information you can do it on:
pesicgordan@yahoo.comIt will be appreciated so much.Thank you,have a nice day
I have a problem with a Daikin Reefer reciprocating semi hermetic compressor that was pull out some time ago. The 9 terminals on the compressor have no leads and were not marked. I need to run this compressor but do not have the wiring diagram. The model no.2HC5BLB-L and was for a Daikin Reefer container manufactured in the 1970's. Could someone show me how to wire up this compressor that as I have mentioned has 9 terminals. I am completely lost.
johnson.lee.biu
Hi johnson.lee,
Is it 2HC58LD-R ? Pls check again its for correct model number. So pls check to the container unit model number.
see you
reefermechanic
Reefermechanic, Friend of mine at another FOB is having trouble with...
It's a 69NT40-541-302 running 1 or maybe 2 degrees of differential on supply/return. Won't cool below 45F here in the high desert. It got a new Controller, "Micro-Link P/N 12-00579-00 or approved equal" before I saw it and fired it up. Ran okay--Except for Alarm 67--but we don't control humidity anyhow, so I ignored it. It ran good for a few months, then cooling petered out.
Checked the usual--cleaned both evap and cond coils, fans run hard, changed filter drier and put in correct 8.75 pound charge of 134a. It pulls 8-9 amps per leg and suction of zero to -10 inches. Discharge runs 110 to 195 as condenser fan cuts in and out. So what red flag am I missing here?
Thanks for a response, the name plate does fade abit.
Anyway does 2HC58LD-R has 9 terminals? It looks like a dual voltage 200volts 3 phase and 440 volts 3 phase.
How do I know which terminals is for 440 volts and which terminals are for 200 volts. A wiring diagram would help a great deal. Hoping for your reply.
Johnson
I have 4 years experience in commercial a/c. I've currently put in for a job as a reefer tech. Is there any basic stuff that would help me out on these reefer units that's different from commercial air? Common problems, and such. Anything will be grately appreciated.
Kf1234
Hi Kf1234
How can i help you?
see you
reefermechanic
johnson.lee.biu
Johnson
Hi Friend,
Pls check your email box ;)
see you
reefermechanic
BIGABOW
Hi Friend
You can use whatsup?
İf you have +905366678279 of my mobile number. Pls write to me via whatsup.
see you
reefermechanic.
Hi reefer mechanic,
I want to know about Dakin and thermo king reefer alarm online checking Web site or mobile applications ? If u have about this , help me share please? Hope for ur reply soon . Thanks
Hi Thein,There is no any wesite or mobile application for your request. See youReefermechanic
reefermechanic
Hi Friend
see you
reefermechanic.
sorry I don't have that app. I will let him know you replied on HVAC-TALK as well. take care......and Thanks a Million!
BIGABOW
Hi Friend,
you have account for skype or facebook?
see you
reefermechanic
I am having code 26 and 32 on a sb 200 thermo king any suggestions?
Hi All,
I am new in this forum. can anybody suggest me how to reset AL22 on 69NT20/40? My understanding is Alarm 22 responds to the evaporator motor internal protectors.
Mohsin
Mohsin Yasin
Hi All,
Mohsin
The better question to ask is, Are the evaporator motors running? AL22 responds to loss of control voltage at TP5 on the controller (ECJ2 on the input plug). Loss of control voltage at this point stops the evaporator fans ans sets AL22. Verify which motor has failed and change it and then use the Alarm key on the keypad scroll to Clear and press enter. Until the evaporator motors are repaired the alarm will continue to appear.
For Carrier Alarm mobile web access go to http://www.container.Carrier.com. Mobile web application is on the Service & Support page. Nothing to download or install just access direct from your phone
Sounds like a failed discharge pressure regulator (DPRV). Mounted in the discharge line behind the compressor. If it fials to open then the unit shuts down on HP
Good day dear. Interested in one question that you probably know the answer. The manual says that the supra Carriers with a jumper to the serial port, you can change the configuration of the microprocessor and change meter hours in case of replacement of the microprocessor. Please tell me how to do it or a link to more information. You can mail in rostov-sl@mail.ru Sincerely Capri.
jhex
Hi reefer mechanic, I recently joined on-board a container ship. We usually loaded Thermoking reefer containers especially the MAGNUM Plus 203 series and Carrier 69NT40 series. Could you please send me a copy of its service manual? My email is:
johnel.aguasa@gmail.com.
Also, could you please advice me on how to clear the datalogger alarm dAL81 of 69NT40 carrier unit?
Thanks in advance. :)
maybe the problem on micro pin
Hi, i neeed mhi instruction manual book, may you hepl me? (mmcciiia-52cpe15-2bwiiinv 2baiiinv, 2baiiifv, 3baiiiav, a2v)
My email adress: nhadth07@gmail.com. Thanks.
capri
you can only change the hours with a computer and tru tech or reefermanger
NGUYENVIETNAM07
http://truck.mhi.co.jp/gen/acrmw/ser...al/manual.html
Hi all
i have a starcool unite and i have alarm for motor evap failr.but in my stor i have not the same motor marc. I have a ABB motor.when i changed the unit work good but a few minut alarm caming again.what you must do.
hi terminal,
u have to change some wiring of new ABB motor.
motor side wire to incoming supply wire
" 4 to 6 "
" 5 to 4 "
" 6 to 5 "
Thank you sur. When i have this problem i wil try to change wirs.thanks
Dear reefer mechanic,I have no possibility to talk via skype.I can use only ship's e-mail.So would you be kind to give me your e-mail.Thank you in advance
Dear bruisermac, would you be kind to give me your e-mail,if you want to send help and support to me regarding reefer containers.My mail is: pesicgordan@yahoo.com I have no possibility all the time to use this forum,only ship's e-mail.Thank you in advance.
I apologize to other members of this community, reefer mechanic and bruisermac are two best men who gave best answers all the time on this forum.Cheers
Someone has the carrier scrl5364.ml3 software, and the software menu0116.m2x?
Please send me m_heckert@yahoo.com
1 Attachment(s)
Hi All,
I have a problem with a 69 NT 511 - 353 CARRIER CONTAINER
The unit seems to be running in a vacuum on the suction side? it is equipped with a modulation valve and quench valve these seem to be both iced upto the suction service valve.
the refrigerant seems to be charged ok because the unit is cooling at a struggle to - 8 - 10C the balls in the site glass on both glasses are at the top.
Please advise if anyone has good knowledge of these units.
Attachment 13853
Probably problem with the regulation valve..
Did you try to re-set the valve to a specific value?
