Re: ac unit condensate water
It depends on the ambient humidity level whether there is any excess moisture to be removed from the air.
outdoor humidity is 19%
temperature is 46 C
When it comes to AC and humidity it is the room humidity that counts.
But with ambient being as low as 19% I guess the room humidity would be really low as well.
Generally if you have a room humidity of less than ~30% there will be little or no dehumidification by the evaporator and therefore little or no condensate.
If on the other hand you got a high room humidity there will be vast amounts of condensate.
:cool:
Hi Kefah,
Glad to see you are keeping well.
Stay safe,
Andy.
