Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Hi reefermech sorry for delay in responding, thanks for your help. I have unit up and opperational. I went through all control switches and contactors systematicaly till i traced fault. When I had no early answers from thread went to old fault finding method. scratch head and test every thing. Thanks again for your efforts hope I can return the favour
Dear all
i work in small container terminal in Hong kong,How can i get information about the reefer container alarm ?
thks
Dear Bro,
Could you please tell me about carrier reefer (69NT40-541 301)? This unit was showing datacorder alarrm (dal 71).Please advise what should I do it?
Dear Mech,
Hope you well. I have a carrier utra that keeps cutting out on low battery. Have placed new battery but still same problem. Is there any way I can stop the the unit from switching off until I have offloaded and get it back to my yard.
Hope you can help
Leon
leon.bez
Dear Mech,
Hope you can help
Leon
You might get Better response if you start a thread under transport
Gents.:)
can some one assist to find the Reefer Data cable connector. for daikin/carrier/thermoking and Starcool.
i need to buy them ....
Any QCM/IRS techs on here??
:Dhi!! every one i am new reefer mechanic but i was HVACR mechanic i am new here so i hope someone can help me in the next other day.
thanks.
i think you can try change into R404a i do it already that then its working good
Re: Latest Software for Daikin reefer
ekbal
Hi does anyone has latest Daikin Reefer software. I am having V6.04. Appreciate if someone could mail to me at
ekbal@shmaritime.com
Thank You.
Hi, check your email.
I send for you DCCS 7.01 (rar file).
topbanana
Dear Bro,
Hi, alarme DAL71 is a failure of return sensor of DataCorder (out of range).
Check the resistence of this sensor (in +25 celsius=10.000 Ohms, +/-50), out of this, replaced the sensor.
sorry my english, I'm practicing to improve.
terminal
tanks my tetsher i have one probleme for daikin end i want solution for this probleme
f 803 end f1o9 end f 107
i wait you soon
i am still have the same problem i already remove expnasion coil solenoid body but the unit it is stilkll goign 0 on low side
I'm working on a reefer container it's compressor over heating due to no refrigerant in the system, but i don't see any leaks on it what could be the problem.
hi ethis is moorthy from qatar, anyone can send me that download link for thermoking reefer manual.
check your condencer and condencer fan motor running speed, check power line of compressor.
reefermechanic
Hi All,
I m senior reefer technician.İf you have got any problem about reefer container units . i will be here....
All the best.
DEAR SIR,
THANK U, SIR. FOR YOUR REPLY.
I have one problem for the THERMO KING unit.CRR-40
rgs the temp pulldown very slow comp suc pruss vacumm, discharge pruss 60psi. set pt-18 ret temp+2c, sup-7c .before starting suctpruss 60psi,kvq value teMP-40C.
Kindly advise sir,
jnb.
we are looking for a cheaper equivalent of Thermoking/carrier refrigertion units for containers. Pls advise.
regards
dhiren
reefermechanic
Hi All,
All the best.
starezone
Gents.:)
hi starezone
i dont have original cable for daikin / carrier / thermoking and starcool. But ıf you want i can make same cable for you.
I m waiting ur reply.
see you
reefermechanic
starezone
Gents.:)
Dhirendra
regards
dhiren
Hi Dhirendra
I think you need old reefer unit. You have to contact to SmithHolland.
http://www.smith-holland.com/reeferservice.htm
best regards.
Reefer mechanic
naga
DEAR SIR,
Kindly advise sir,
jnb.
Hi naga
did you check TXV? Check its.. Do you know how can you check its?
See you
Reefer mechanic
ekbal
Thank You.
Hi ekbal
you lucky;) its ok. check ur mail box;)
see you
reefer mechanic
reefermechanic
Hi naga
See you
Reefer mechanic
THANK U SIR,
What about check the TXV.
Pls reply.
naga
THANK U SIR,
Pls reply.
What do u mean by super PTI.
Have sombody experiance whit a diesel/elektical reefer
45ft slx 300 from themo king
thanks
help with thermo king cbci unit compresser is pumping ***** but nothing geting cool in air handler
Hi reefermechanic,
I need alarm list for mitsubishi cpe 14 .Thanks .nickzarin@gmail.com
nickzarin
Hi reefermechanic,
Will this do ?
http://mhiks.mhi.co.jp:13081/acrmw/s...E14-2BA3ES.pdf
Will
:):):) thanks WILL very helpful...
reefermechanic
reefer mechanic
Reefer mechanic, why did you edited your original post into all periods....................?
Please help me reefermechanic.
how to reset reefer alarm (carrier transicold) if the display is written AL52?
Hi James, all of Carriers container manuals are available on their website.
Carrier Container Manuals
AL52 = "Alarm list full",,,,,scroll through the alarm list and see what the other alarms are and post back.
Please help me.
I need Thermoking ThermoGuard MPIV User manual
pkfo
Please help me.
rio_rio_rio@mail.ru
People, help me please-e-e-e. I have a problem with controller MP-3000. A LCD display show EMERGENCY PROGRAMM what is that? When i want to enter to MAIN MENU and press the keys F2 and F3 nothing happens :mad:.Sorry for my bad english i hope you are understand me.
v500 2008. not running on electric. unit does self check then then the screen goes blank 12v truck. good 3 phase good 12v from transformer. changed micro p, transformer, cab controller no good. any idea. Dealer called not fixed yet!!!
What is it what you want to keep "cool" when the ambient temp is -40?
No,only fill the right *****, r404a runs with much higher pressures.
