Re: Question on line size
Are we allowed to use a tube expander directly on the fitting of the compressor?
I'm guessing its just a little embraco black pot compressor, with ports made of copper that youve got.
I dont know what the manufature recommends but. In the past I've used tube expanders to just slightly widen the compressor ports, so that you can fit standard copper tube sizes like 1/4" and 3/8". Carefully heat up the compressor port before using the tube expander so that it dosnt split the pipe.
Another option that is not so advisable to use. In the past on the very odd occasion when the compressor port or the copper pipe is a really funny size and dosnt fit. I've either expanded the copper tube so that it fits tighter into the compressor port, or expanded the copper tube so that is fits over the top of the compressor port. Again this is not so advisable.
Thank you Sean. Yes, it's a standard compressor for small freezers and refrigerators.
I also thought I could take a look at another applicance I have at home, a blast freezer with R290. Oddly enough, they decided to put a 4mm OD pipe out of the discharge and into the condenser, also they put a lot of brazing material to fit the narrow tube into the inlet of the condenser which seems to be a 6mm or even greater.
If you do try and fill a large gap with brazing material, just keep in mind how much brazing rod your using. Its easy to use too much and end up causing a restriction or even block the tube.
For correct sizing, you need capacity
