Refrigeration system in cold countries
Hello everybody
I am design engineer for propylene based refrigeration system which will be located in cold countries. Ambient temperature varies from -32 C to 44.8 C. can anybody tell about special precautions that we need to take care while designing refrigeration system for ambient conditions??
Re: Refrigeration system in cold countries
Hey.
Design systems with free cooling option. (saves a lot of power)
Heating element in compressors.
Control of condenser fans, for high enough condenser pressure at low outdoor temperatures.
Which company do you work for?
Kay
Thanks Kay for such a prompt reply
can you please advice me on the selection of motor for ambient conditions such as -32 C to 44.8 C?
and do we need steam tracing / electric tracing for lube oil system
You say that there is a propylene-based cooling system......
Is it a water cooled evaporator and air cooled condenser?
What temperature should you have on the water? 7/12 degrees?
I must know a little more about the system design to make recommendations, but maybe that it's a secret :-)
Kay
kayern
Kay
thanks for prompt reply
It is water cooled condenser and water inlet outlet temperature is 32/42 during summer .
It is water cooled condenser and water inlet outlet temperature is 32/42 during summer .[/QUOTE]
I need your assistance .. please reply
