5h Main Bearing Removal And Inserts
What Is The Procedure Of Removing And Inserting The Main And Pumpend Bearings For 5h46 Carlyle Compressor . Pls Explain In Detail, Better If Thereis Any Picture Of Procedure....and What Tool Is Used For Removal & Inserting Bearing, Where It Is Available, Also Any Website Too See It...pls Help.........
Re: 5h Main Bearing Removal And Inserts
treaded rod, a bit of pipe to fit over the bearing and a flat plate will suffice.This will also enable you to refit the bearing.
Info possibly on the carrier web site.
Kind Regards. Andy:)
