i have to put this in a system using r22 the oil in the system is not mineral i guess i know the answer just seeking clarification the dye i use is spectroline which type should i use it must be the type that suits the oil?.
Yes.
However, if you look at the spec of the dye you will find that one type only does mineral oil whilst the other does synthetic or mineral...
