Electrolux TR1241 fridge freezerneed thermostat
we have had my late parents fridge freezer for years but today the thermostat has died on us..i checked continuty and found its gone open circuit so tempory fix i have shorted the 2 pins out on thermostat..
i need to locate one asap but there seems to be so many types?
please help
p/s the freezer section is fine...
Re: Electrolux TR1241 fridge freezerneed thermostat
You need a Ranco K59 L1102 (VT9)
Stu
hi Stu
thanks for quick reply could u recommend where i could get one mate in uk...
ive had the thermostat shorted for abt 3 hours now and temp is down to 10c and dropping..
thanks agn
paul
Tonto posted a link for the stat.
Stu
Hi Stu
just found what u posted on Ebay can you confirm this is what i need as its alot cheaper than tonto link
cheers agn paul..
will buy now if u agree
That's the one
Stu
thanks guys for all your help especially on a sunday night...
ive ordered off ebay will let u know how i get on....
once ago thanks all....
paul
hi all the thermostat arrived today part number Ranco K59 L1102 (VT9)
the new one has 3 pins<spade conn> my old one has 2 can someone tell me which pins i need to use the earth is obvious as i see that connects to case like old one which 2 wires black and brown go where?
any help please as it come with no instructions
got wrong one then as there two differnet ones for this fridge:p
im well confused now i looked up the one on part masters that has 3 spade connections aswell..so anyone know where i can get stat with only the 2 spade conns?
cheers
paul
hi thanks tonto33
it seems to be right from what i can see in picture but at that cost i will have to sleep on it..
wish i could use one that arrived hell of a cost difference...
thanks agn
paul
Brown to terminal 4
Black to terminal 6
Stu
Bit late but 6 and 4 are the ones, Ta stufus, and 3 is for heater, but you don't have one so forget it. Some sparkies on this island attempt to cut capillary to size which is a bad move. Roll up what you don't use.
I was working away Mike .
Sticking to the bigger stuff.
Used to do domestics with my father before he sacked me for chasing the housewife's;)
Stu
Hi guys its me again fitted the new vt9 thermostat last night and waited to see if it switched off ok
voila success all working well.. connected wires to pins 4 and 6 as you guys suggested..checked temp today and its a constant 5c wife happy im happy bank happy...even got the light to work when u open door....changed bulb but found the sw that opens when door opens was jammed took to bits put back together now all fine...
think total cost was £5.99 thermostat £2.25 for bulb not a bad price to pay...
thanks to all of you that helped me through this...
cheers agn..
paul..
No worries Paul
Glad to help even if I was a bit late coming back
Stu
