i have light in fridge but it is not cold & freezer has defrosted...have turned thermostat up & changed fuse but still same??
would need to know what model this is, some have thermostat which could be faulty, some have defrost timer which could be stuck on heater and some have p.c.b which could be the fault. if the compressor is not starting but is hot it might even be that
hi, if the only thing that works is the interior light then i would say almost everytime it's the themostat. if there is no power to the compressor there will be no sound at all and the compressor will feel cold
