wHAT IS THE PROCEDURE TO SELECT THE CAPILLRY TUBE OF ACCURATE SIZE.
THANKS
THANKS
Hi, AMARNATH,
http://www.supco.com/images/20%20cap%20tubing.pdf
This was addressed in a different thread. You can search for key words and perhaps you could have found it yourself. Try searching the forum. I think there are other answers already posted to your question that may be more helpful. I just searched "capillary tube."
Hey have a look at this thread from this very site.
http://www.refrigeration-engineer.co...ead.php?t=3800
Som pdf's to help you further
Originally Posted by Peter_1
Thanks a lot peter_1
If you have some more information please send to me
we have installed water chiller, euiropean designed, we convert it to 60 hertz, we change the pump and the primary transformer, my question is ? what is the effect in refregiration system of the water chilller,,
i hope someone can give an idea on this .
thanks nico
My opinion: not much of a change. a) you will change slightly the capacity in TR (change in COP); b) change in energy consumption; c) may need to check loss in kw (because of cos(phi)
If there is anything else please let me know.
Fastco
