Can anyone advice me on manufactures of Chilled Display cabinets.
Manufactures name -must be located in the UK. :cool:
Hi Kewlman,
Where do i start !!!
Foster, Williams, Arneg, Surfrigo spring immediatly to mind.
Can you give more details.
Size, Integral or remote, Temp range, Multideck numbers.
Literally there are hundreds with outlets in the UK. Give us as much info as possible and the guys will try and steer you in the right direction
Fatboy
hello kewlman
there is absolutely loads of different types what type of display are you looking for a company we use is called ABERNA they arebased just outside of london and do quite a large range [different shapes sizes etc] or caravell they are in buckingham and you can get what they call grade f which basically means it has a minor dent or scratch but it can be a lot cheaper
