AIr to water heat pumps wich is the best for nordic climate(industrial) ?
As we all know air to water aplicantion can give some challenges.
Any brands better than others?
50kw ->
Regards newbie
Re: AIr to water heat pumps wich is the best for nordic climate(industrial) ?
For the duty that you have mentioned, your choice will be a little limited as you either need to cascade several units together or use one of the slightly larger commercial units.
I would definitely use Samsung DVM S VRF system with hydrounits as indoors.
I have installed hundreds of these as single and "multisplits" and the customers are extremely happy with them.
