Re: Refrigerant migration
I think the refrigerant will migrate with either line set length, maybe the thinking behind the crank case heater recommendation (other than cost cutting) is that with a shorter line set there will be less charge to migrate to the compressor and cause problems.
If it were my system I'd fit a crank case heater no matter how long or short the lines.
Refrigerant will migrate because of pressure equalizing when compressor stops. CCH is always good thing to use.
Most manufacturers of small ac units will not use it to cut costs.
Most of the newer a/c units with scroll compressors run a small current through the windings when the unit is off to prevent refrigerant logging in the sump. This does away with a CCH.
frank
Thank you all for commenting.
It sounds like what I thought is correct, I want some heat on the compressor regardless of what the manufacturers claim.
Frank,
I haven't seen the scenario you describe, at least not yet. All of the wiring diagrams show a contactor that totally disconnects the compressor.
MrTube
Frank,
As I say, it is the newer models, i.e. inverter driven, that have this
Does your unit have an accumulator?
frank
Ah I see.
No, no accumulator.
