1 Attachment(s)
Soap Plant Load Calculations
Good Morning to Everybody.
I am happy if anyone clears my doubt.
I am having the following enquiry for a soap plant.
Soap Plant Dimensions: 54 x 32 x5 m
Room Temp: 25ºC
Electrical Power consumption of Equipments: 35 KW
As per my calculations the total heat load is 117 KW
But my customer having some quote from Industrial air-conditioning having heat load of 265KW for the same plant room.
My doubt is the heat load for the plant room should be same either for refrigeration or air-conditioning. The processing will be the different. How it could be 265 KW for air-conditioning.
I attached my worksheet for your reference. But I don’t have the work sheet for air-conditioning.
Thank you.
TJK
