So dears, My name is Alex and I will try to explain something thath bothers me a lot... And an idea thath maybe will do the trick.
When I use my vaccum pump the motor gets hot... well about 70ºC or so, this is aint a problem, however I have seen when i use the pump in continuos use (about 40 min or so) the pump takes wayyy longer to achive the vac, so remeber the hot motor??? its heating the oil!!!
So... one simple and very nice solution for me as an engenieer and hobbyst is to... Make an small coil, and attache an air vent... And a small gear pump, will be moving the oil from the pump to the colding coil... simple and nice... So I have some questions for the kings of the forum:
1.- whath do you think thath will happen?
2.- Is this a mad idea? -of course but how much-
3.- Witch be a nice temperature for avoid or to delay as much as possible the oil turn to molecular flow, decreasign the vaccum capacity.
4.- Dont you love this forum?
So... I hope grab some atention... Keep up the good job...
Animo!!!
