Copeland Copelametic compressor specification table
I just finished a Copeland Copelametic compressor application table and put it on the web. I hope everyone finds it useful.
Just click on: http://www.hvacrinfo.com
and follow the link to Copeland Compressor Specifications "Data" in the right hand column.
Re: Copeland Copelametic compressor specification table
i'm looking for the technical specs for a copeland scroll compressor ZR73KC-TFD-230 Can someone help me out?
delchariss
I don't find any information on a ZR73, but there is a ZR72.
It's a high temp R-22,
380/420-3 volt 50 HZ
60,500 btuh @ 45/130/65/115
460-3 volt 60 HZ
73,500 btuh @ 45/130/65/115
know where i can find starting components specs for these compressors
mattmp2006
The easiest way is to go to the Emerson website and register (simple process) and go to "Online Product Information"
www.emersonclimate.com
i m new can you tell more on high temp. low temp comp. difference.
can i apply high temp comp to
low temp refrigeretion.pls advise
thank you
maxair99
thank you
The short answer is that it depends on the compressor model and btuhs required. There are other factors to consider but this is where you start.
