Re: Pressure drop through the suction line accumulator?
frank721
Thanks for your suggestion. there is no other device between the accumulator and compressor. But you bring a good point: kink in the line. In fact, the diameter of outlet of accumulator is 7/8" and diameter of inlet of compressor is 5/8", but they are connected with a smaller tube of 1/4"
is it the reason that cause the big pressure drop?
Are you serious? A 1/4" connecting line? :eek:
desA
I read that several times and it just didn't register that anyone would actually do that... lol
frank721
Yes... that would definitely do it.
Yuri B.
Hi Frank.
What temp air off evap ?
hi, my evaporator is used for liquid cooling like cooling system in the desktop now. so, there is no air off evap
Gary
Are there any devices between the evaporator and the accumulator?
Gary
After reading your other thread, I am even more confused. This is either an A/C system or it is a cooler system that you are trying to convert to an A/C system. Which is it?
desA
Gary
yes, it is 1/4" really.
there is a needle valve between the evap and accumulator. but it is fully open. pressure drop is not significant when fully open.
it seems that we have found the cause of the 2 bar pressure drop:7/8" to 1/4"
thanks a lot, my friends:)
1 Attachment(s)
For discussing conveniently, i post the schematic of the evaporator. i measured the pressures at Point 1 and 2.
frank if suction line diameter is fixed by size of accumulator port,what the hell happened.when anyone has a vague out i call it the autoduhh syndrome it can happen any time.
interesting picture whats it of frank
I think your compressor is going to suffer the world of pain, sooner, rather than later... :(
That's a flooded evaporator... and a whole different ball game.
Interesting drawing, looks like a oil recovery bottle on a flooded ammonia evaporator.
If not ammonia, could be anyones guess.
I can see why you have a 2 bar delta P from evap to compressor, with 3/8 dry suction.
OK, I went back and read the original ost again, its R134A. Could still be a scavenge oil recovery line that rises up in vessel to control level, the 1/4 "line would restrict flow and limit it. Also the 3/8 dry suction may be intentional to restrict carry over.
What controls liquid feed to flooded evaporator ?
lowcool
the inlet of accumulator is fixed, but you can use adaptor to reduce the diamter:confused:
desA
why do you think so? sooner not later?:eek:
Gary
as i said before, this system is taken over from other people. so i want to figure out the problem.
do u have any suggestion on this so-called flooded evaporator?
thanks a lot:)
Magoo
what do u mean by "scavenge oil recovery line that rises up in vessel to control level"?
can u elaborate it?
before the evaporator, there is a manual valve to control the feeding liquid.
frank721
My concern is about liquid slugs getting into the compressor, if the system is not controlled carefully.
If that's all taken care of & guaranteed as a non-event, then rest easy - if not, then you may want to research further.
dunno here we go years ago came across this sort of cascade system and i reckon that something like this was used on the expansion recovery,over run what ever circuit,come suction accumulator what ever to keep the feed up to the refrigerant pump.must say it was a little bit bigger on sizing but.ammonia blokes should have an idea
anybody else good for ideas
The 1/4 inch pipe you mentioned is usually a support pipe . I have in one instance noticed that one of the pipe tilts if you test the accumulator indepedently . So to my knowledge it is a support pipe . Just check with manufacturer . Besides, give me the following data to select the right model for you to compare.
Refrigerant
evap capacity
condensing temp
evaporation temp .
desA
ok, then what do u think shoud be taken care?
lowcool
thanks, any experience on R134a?
D.D.KORANNE
Refrigerant
evap capacity
condensing temp
evaporation temp .
Refrigerant : R134a
evap capacity:1~1.5kW
condensing temp:40~50 degree C
evaporation temp:15 degree C
Thanks a lot! by the way how to transfer cooling capacity in unit of "tons of R22" to "kW of R134a"?
