Re: Carel PCO - programming
Blue box chillers use a proprietary software solution. So if the used pCO2 is not of the similar chiller you will not be able to fit it.
Phone swegon they will have to get the correct pco from italy could be a wait mind
pCO2 are really old now and have been superceded twice ! not gonna be a simple plug in plug out solution for this one as you'll need a newer generation pco5+ controller to be configured and set up from scratch.
1 Attachment(s)
You can use pco key to download and upload software , see attached
Can you provide more details
you can transfer a pco from one chiller to another as long as its the same chiller also bear in mind most chillers will have a slave and master
you can also down load the software using the pco key as its a pco two you will need the plug in type not the mouse thats for pco 3 and current
also pco two is now obsolete if you are in need on a new one i have 4 brand new ones
