Twin Condensor bottle cooler?
Hi all,
went to a friends bottle cooler behind a very tight bar last night. After removing the back I noticed it had '2' condensers but only one compressor. Both axial fan motors had gone. I'm not very up on bottle coolers so found this bizarre. Is that well known running gear for them?
Thanks.
Re: Twin Condensor bottle cooler?
A "Tight Bar"?? Does that mean the management is known to charge for the 1/2 glass of head instead of the mostly full glass of brown intoxicating liquid?:D
Install condenser fan(s) as the others are absent without leave.
Two condensers on a bottle cooler is not considered to be "standard" practice when only one compressor, (probably 14 or 16 CC's) is used.;)
u not mistaking the bottom section as the re evaporation trough for the condensate?
