Can anyone shed light on any fittings available to hook up to open lines were the outside unit isn’t fitted yet . So basically to braze on the outlet lines of the indoor unit only.
You shouldnt need a high pressure, so you might be able to just tape a gauge hose in/on the pipe. If the hose end is too big, connect a shrader valve with a copper tail to the gauge hose.
Thanks I’ll try that
Got one of these thingies but was much cheaper, think had to import it from the States,
https://www.amazon.co.uk/Nitrogen-Pu...s%2C204&sr=8-4
