Sanyo (Panasonic) ECOi Capacity table for 22 to 60 HP OU
Hi Guys,
Sanyo (Panasonic) technical manuals for VRF (ME1, MF1) does not contain capacity data for OU combinations 22HP to 60HP. Only 8HP to 20HP is available.
Can you please advise how to calculate combination data….or is this factory data?
I need this data to compare capacities at 30%, 100% and 130%.
I'll appreciate any feedback or advise.
THANKS
angelmarina
Re: Sanyo (Panasonic) ECOi Capacity table for 22 to 60 HP OU
send a message to techguy he's the man
Hi Angelmarina,
22hp to 60hp system are just multiples of the smaller models.
ie
36hp = 20hp+16hp
54hp = 20hp+20hp+14hp
So you just look at the data for the 2\3\4 smaller outdoor units connected and add up each of the figures to make the whole system figure.
Sure it's a little clumsy but I think it should work.
Loops
Hi Loops,
I have checked your approach based on Daikin capacity tables (RXYQ-PR).
The sum of TCs and PIs of stand alone units are different then in combination.
PI(8HP)+PI(10HP) is not equal to PI(18HP). PI means Power Input.
AM
