FRidge Freezer samsung rsa1 american style wont chill
FRidge Freezer samsung rsa1 american style wont chill, and the freezer won't freeze, when i got it i switched it straight on only to read after that that i should have let the gases etc settle for 24 hours, so i swithched it off and left it, i turned it on the next day and the temp dropped fine, the following day when i woke up the temp was high again and now it won't drop at all. the digital display works fine and the air blowers inside seem to blow fine but it won't go cold, pllleeeeease help, regards, stuart
Re: FRidge Freezer samsung rsa1 american style wont chill
mr.
restart u r frig after shuting it for 24 hour if it works even for 8 hr then stops . then it is the problem with timer, sensor, or heater, u r defrosting system is not working contact tech .
with rgds,
it doesnt cool at all. even if i leave it sit.
the reason that you are supposed to let a fridge sit is only if it has been layed down, to let the compressor oil drain back into the compressor which can run out into the pipework when it is laying & cause damage to the comp. nothing to do with the gas. sounds like you may have damaged the comp.
