Re: Carter Serve Over Switch
Self serve counter would have front glass removed so bigger cooling duty, is solid state yoke just a delay to stop both comps kicking in?
Have one site with the RDM, painful to use when you've not doing them frequently.
Hi Al, thanks for the reply.
Second comp came in when switch moved to serve over which made me begin to question why it went that way round as load is now less. Well, assuming switch is wired like the sticker next to it!
RDM has a setting for controlling 2 comps but I don't know if it is set up for use, only saw the setting when sat at home having a look at the manual in a bit of peace and quiet.
Yes, bit painful to get back into. Messed about a fair bit when we did the Co-Op's but that was a while back so a bit rusty. Glad to have found air on and off probes wired opposite way round on this model amongst other faults though.
2 Attachment(s)
Had the privilege of going back to it today, condenser fan out, but in a shop at 30*C sure I'll be back...
Anyway, got a couple of photo's of the controller.
Attachment 11605Attachment 11606
