Where could I find a fan evaporator able to to blow its air flow in two directions 90 degrees each other? Any suggestion about manufacturer of such a similar device? Have a look to the attached sketch...
Thanks for any incoming suggestion.
Hi Coriolan,
bit of a strange configuration, I would expect you would have to get this made by a cooler manufacturer specially. Whether or not this would be viable would depend on the size and number required.
Goehart would be my first choice, but there is others, Kuba ect.
Regards, Andy:)
Hi Andy,
thanks a lot, even if you told me what I was afraid of.... :(
Anyway I'll find some trick to reach the result.
Have a nice day and thanks again.
Coriolan
Why not put two unit coolers at right angles to each other? What am I missing?
