Mr Slim remote control not working
Hi All,
I have a Mr. Slim A/C unit with heat pump.
It operates fine by using the manual buttons SW1 & SW2 to allow heat/cool to 24 degrees Celcius.
But the remote control does not operate at all. It does not even beep when pressed. I have tried the obvious program code changes but still nothing.
Could it simply be the IR control board or is it deeper than that?
Re: Mr Slim remote control not working
What about changing the batteries?
Have you tried zapping it against the camera on your moblie phone?
Is the IR sensor correctly positioned?
Chillin:):)
