Hello
I have a compressor replacement to do on an old daikin ducted system and was wondering if it is good practice to replace inverter PC at the same time? The inverter PC checks out ok but is approx 12 years old'
Any advice/tips much appreciated
Hello
I would replace.
Nothing worse than fitting the expensive new compressor to have it blown by a dodgy PCB.
Thanks Brian
Always replace inverter board when changing a compressor these days 👍🏻
And ascertain why the compressor failed suction filters are an easy install
So what about replacing bldc fan motors when replacing Inverter PC boards, I often do but if they check out ok .....
Interested to know what others do.
replace a 12 yr old system
