Any standred to charge the R134a in any refrigerator
Hi every one :p:p:p
i 've one problem that did we've any standred to charge refrigerant R134a in any system
how much we charge ???? :confused::confused::confused:
speacial attention to :cool:
Mr. MG PONY
MR. BRAIN UK
MR.ICE MAN
MR. JOSIP
MR.NIKE
thanks and best regrads
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
Re: Any standred to charge the R134a in any refrigerator
You need to charge by superheat and subcooling regardless of refrigerant.
Correct superheat ensures that there is no liquid at compressor suction (because liquid cannot be compressed) and if it is to low compressor could be damaged and if it is to high, evaporator capacity is lowered, because that excess superheat is not useful.
Correct subcooling ensures that liquid is present at inlet of expansion device, and if it is low, some evaporated refrigerant enters in expansion device lowering device capacity and, also, could damage it (TXV). High subcooling uses higher part of condenser for storing liquid refrigerant, and lowers his heat rejection capacity.
Refrigerant charging must be balanced in that manner that is in all working conditions ensured minimum superheat and minimum subcooling and in same time that useless subcooling and superheat is also minimal.
Amount of superheat and subcooling is dependent on construction of appliances and working conditions in time of charging.
Good guide for AC is Jim Wheeler charging article:
http://tinyurl.com/56jrzl
For refrigeration I don't have any link or table
AoA
MR.IBRAHEEM
what is this
i've problem in charging and u reply with your problem
you make a new thread for your problem
don't ask your problem in other s thread
i think u understand it
thanks for ur coopration
thanks a lot
jahangir ahmad khan
Lahore pakistan
jahangir.ahmad
AoA
MR.IBRAHEEM
what is this
thanks a lot
jahangir ahmad khan
Lahore pakistan
As Nike has said, there is no "standard" charge, the charge must be tuned to your fridge.
Add refrigerant till you just begin to see frost on the suction line, then with this charge allow the fridge to pull down to the temperature of 2C, then you adjust the charge to get proper super heat and sub cooling.
After this you will watch it and test it at several different condensing temperatures to ensure it is good then seal it off.
Good luck to you and your venture, I am sure you will succed.
Good after noon
thanks a lot
for such a nice information MR.MG pony and same to u
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
I'M ALSO waitingFOR THE COMMENTS OF .
MR JOSIP
MR.Brain uk
I'M WAITIN FOR REPLY
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
goood morning
i'm still waiting the comments of MR.JOSIP AND BRAIN UK
IF U READ IT AND DON'Y HAVE ANY INFORMATION ABOUT IT KINDLY REPLY ME SIMPLY
REMEMBER I'M STIL WAITING FOR YOUR REPLY
THANKS AND REGRADS
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
hi good morning
some of mine friends told me the thumb rule ' that fill your tube 70% and see that back pressure is must be zero (0)
send me your comments about it
attn: MR JOSIP
THANKS
JAHANGIR AHMAD
LAHORE PAJISTAN
jahangir.ahmad
hi good morning
attn: MR JOSIP
THANKS
JAHANGIR AHMAD
LAHORE PAJISTAN
Then, you just listen those friends of you.
good morning
i'm asking your suggestion
this is just a thumb rule
i'm asking that did we have any thumb rule or not like this
don't to be angry i'm just telling u to confirm it
if u r not agree then its wrong
clear
thanks for reply
Jahangir Ahmad Khan
Lahore Pakistan
GOOD AFTERNOON
MR.NIKE
I 'VE NO WORD S TO SAY THANKS
THIS IS GOOD EXPERINCE IN YOUR LIFE
thanks a lot
jahangir.ahmad
GOOD AFTERNOON
MR.NIKE
thanks a lot
This quote is not my experience, it is quoted text of Jim Wheeler.
nike123
who is jim wheeler?????
ok thanks again for your kind information
one question which company you r working ??
jahangir ahmad khan
lahore pakistan
jahangir.ahmad
jahangir ahmad khan
lahore pakistan
Did you ever read post no.2 in this thread?:eek:
Jim Wheeler is an award-winning writer and teacher with more that twenty-five years in the field of HVAC.
http://tinyurl.com/3q3bv6
I am selfemployed!
nike123
I am selfemployed!
in which country ???? and company also and designation too
thanks
jahangir ahmad khan
lahore pakistan
jahangir.ahmad
thanks
jahangir ahmad khan
lahore pakistan
No company, no designation! I work from job to job for cash money (tax free :D).
Why do you ask that?
