Hi Everybody,
I have a Samsung Vivace AQV12 which displays temp in F. I simply want to change the display to C degrees. There is nothing about it in the user manual. Anybody can help?
Thank you
Fred
Hi Everybody,
Thank you
Fred
do you have a hard wired remote controller or infer red?
I have the infra-red remote delivered with the unit.
Fred
Thank you Paul, much appreciated.
Fred
OK,where is the unit displaying the temp in F?
on the indoor unit blue LED display or on the remote control?
i think you cannot changed the display to C
due to F is the default in the micom
You can only set in the remote is the option codes of the unit, temp setting, MPI etc..
With panasonic's you hold the up or down arrow down for 10 seconds
Maybe just try holding one of the buttons down for 10 seconds....
Sorry for my late reply, I was on a business trip.
Both the display on the unit and the remote are displaying the temp in F. I do not mind about the remote (I can probably buy one in C) but the display on the unit is annoying.
I have tried several key combination (including "up" and "down" key) but my guess is that if it would be that simple, Samsung would probably publish it in the user manual.
Do I need to change an EPROM or something in the electronics or can it be changed in the factory settings?
Fred
Bump. Anybody knows?
Thank you
Fred
from as far as i know this unit has rolled out of the factory in F and cant be changed,have asked the UK team and they are scratching there heads but if i know more i will ask
