oil pressure control is a differential pressure control with timing time ( 45 up to 120 Sec.)
Inlet pressure to oil pump + oil pump pressure = Outlet oil pressure
In pistons compressor Inlet pressure is a suction side pressure , so in reading pressure of oil(out let oil pressure) we should reduce suction pressure to find our oil pump pressure.
But in screw compressor with oil pump our inlet pressure is a discharge pressure .
Best way and only way to check oil pump works is pressure of pump and noise of pump.
To check oil pressure controls works , it has testing indication arrow to push it .
