Re: Sanyo p 20 fault code
Hi Matt,
P20 = problem with gas charge ie high comp discharge tem \ hp trip or the C2 sensor exceeded 55-60°C.
First off I'd check all the sensors - both temp and pressure sensors. You can do this via the wired controllers. Or hook same up to the outdoor to read sensors more simply.
Next I'd verify gas charge is correct - weigh it out and compare with commissioning sheet \ info for total system charge.
Environmental Site Supplies in Sutton, Surrey are ex-Sanyo distributors give them a call and ask for the Tech support, should be able to help.
Loops
