https://youtu.be/n8ynvgPp7jI
Rob
Rob
Temperature is hard to read.
What's the matter Brian?
Are you not familiar with the new fangled temperature range called Celsius :) I could have done it in Fahrenheit :D
Rob
Centigrade ha ha
No Rob, I simply meant that I couldn't see the display on your thermometer.
[Edit] Reset the brightness level on my tablet, bit readable now. Ooops.
So your good with modern metric scales just not with tablets :D
In truth when I show it on a big screen the temp is hard to see sometimes
and I always put it down to the projector bulb colour but I think you are right
if I did it again I'd use a different display.
I did do it once with a probe through the bung in the water but gave up after
the probe failed, I don't think it like being in a vacuum and in water :)
Rob
