Hi Guys,,,
Fridge freezer 50/50 R600 single compreesor freezer about -18c but fridge only 10/11c what do you think may be pcb?
Hi Guys,,,
Does it have a 3 way valve witch feeds the fridge or the freezer, then often the relais or Transistor on the pcb is dead.Quote:
Originally Posted by ice-cold
If it is a single circuit just fix it.
CHears
Victor
What make is it?
how does the fridge get its cooling (evap at the back of air from the freezer)?
is there seperate controls for each compartment?
any other info would help
I freezer runs continuous, what temperature can it reach after 2 /3 hours? If not loiwer than -25°C, lack of gas.Quote:
The fridge gets it cooling from the freezer from a baffle up the back of the freezer then into the fridgeQuote:
That is correct but if the water hole is blocked, the evaporator is becoming a block of ice and prevent from the air to run into the food compartment.Quote:
My experience shows that by disconnect it from the mains, cleaning the defrost water passage and all the food remains from under the freezer bottom, would do the job.
Chemi :)
I have checked the condensor it is fine my be sort of gas or pcb needs replacementQuote:
Originally Posted by chemi-cool
Well fix it then!! :confused:Quote:
Is aircon and ice-cold the same person or are you both fixing the same job?
i registered twice by mistake i did'nt know how to use the website...............
Another mistake..............post domestic issues under Domestic, not Commercial.
That way the Domestic fundies will see it.........and probably assist
Thanks,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
