what is the utility of the ZNR
in the indoor unit PCB
of LG mini split ac
24000 btu
220volt
50 hz
http://www.mediafire.com/convkey/b99...154cezb3zg.jpg
of LG mini split ac
24000 btu
220volt
50 hz
It is a surge protector.
A common mode acting filter with a high, broad band attenuation ratio.
A ZNR varistor surge serves as the overvoltage suppression component.
The earthed capacitors are tested and approved as so-called
class Y noise suppression capacitors.
See page 7 of the document below.
http://www.schurter.co.uk/content/do...on_PG80_en.pdf
Good to hear you are well and still able to post.
Rob
thank u pal
that really helped me
im still fine till now
