Re: water pressure problem
if you give a sketch ,it will help to understand your question:)more.
rest regards
LC
hi feind
the water pressur must be out from the last terminal of usage at perssur 1.5 bar.
you said you have 12 m hight building,(app.1.2 bar)
the elbows and bends and strainers takes 0.5 bar app.
so a rough calculation gives
1.5+1.2+0.5=3.2bar
the amount of water ,must be sufficent to several uses of water,
this the least pressure the pump must delever to water network
moreover you
may have strainer blocked , that reduces water pressure
all regards
afeef:cool:
1 Attachment(s)
Here is drawing.
Best regards,
Ranato
